Edited by mike (Aug. 15, 2011 01:32:31)
goliathdrakken
If the plan is to depreciate the pykeg core, does that mean that a USB host Android tablet will be required to run the kegbot core?
goliathdrakken
It would be nice if the tablet doesn't have to be dedicated to kegbot use.
goliathdrakken
If remotely it would be nice to make the kegboard network capable, and able to communicate directly to the database, and eliminated the need for the tablet as a middle man.
goliathdrakken
On another note, love the app. Looking forward to its release. Out of curiosity, is it developed using compatibility fragments so it will function on phones as well, with limited functionality of course?
I'd love to see someone pull off a cheaper ethernet-only kegboard with the web API. I haven't turned a patch away yet
Thanks! Good question -- yes (mostly). All of the main blocks are fragments, though I've not yet attempted to use it on a pre-Honeycomb device.. Definitely something I'd love to see happen. No reason you shouldn't be able to use this app to build a cheap core with a used phone, or just as a data browser..
wifigod
Might have to play with one next time I'm @ Best Buy. Can do a quick review on one if anybody's interested.....
goliathdrakken
The first problem I see with this tablet is the lack of a USB host port. Thus it will not be able to provide a connection to the kegboard.
goliathdrakken
On second thought, it would be nice to make a kegboard that works on the Arduino ADK. Then the only requirement for the Android device is that it runs 2.3.4 or higher, or (3.1 or higher for tablets). This would allow for use of tablets that aren't $500.
The app still needs a little more testing and polish before I feel ready to release it (and the source), but I'm conducting a small private beta right now. Longer term, the python core will be deprecated in favor of this Java implementation. There's a zillion things I'd love to implement and just haven't had time for, so I'm excited about where this can go.
It is now my mission to find a sub-$200 tablet that would fit perfect with this new Kegbot I'm planning out.
wifigod
That does sound neat, but the ADK is $90, plus you still need another $80 for the shield (which I assume would still be compatible? I haven't used a Mega yet, so I'm not 100% on that), PLUS an android (that you'd have to keep connected to the ADK while using the keg) device; it just starts to get expensive and the requirements go up a decent amount.
goliathdrakken
Actually the link I posted is an all in one package, it is a mega with the USB host built in, so if you want to do Android accessory prototyping using an Arudino, its definitely the way to go.
Edited by wifigod (Aug. 16, 2011 17:50:29)
