JLPete
# Aug 09 2010 - 2:08 PM
Milwaukee
Anybody have a picture or pin outs for the mega board?
geoffculp
# Aug 11 2010 - 7:08 PM
Milwaukee, WI
JLPete,
The only other pins used on the Arduino Mega are the extra hardware-interrupt pins (18-21).
#define KB_PIN_METER_A            2
#define KB_PIN_METER_B            3
#define KB_PIN_RELAY_A            4
#define KB_PIN_RELAY_B            5
#define KB_PIN_ONEWIRE_THERMO     7
#define KB_PIN_ONEWIRE_PRESENCE   8
#define KB_PIN_ALARM              9
#define KB_PIN_BUZZER             11
#define KB_PIN_TEST_PULSE         12
// Atmega1280 (aka Arduino mega) section
#define KB_PIN_METER_C            21
#define KB_PIN_METER_D            20
#define KB_PIN_METER_E            19
#define KB_PIN_METER_F            18
Cheers,
Geoff
JLPete
# Aug 13 2010 - 8:08 AM
Milwaukee
Geoff,
Hello from Wauwatosa, WI. Why does it not surprise me that Kegbots are being built in Milwaukee? Any way I have seen this in the Kegboard_config header but on my Mega. pins 18 19 20 and 21 are labeled as serial RX and TX pins while pins 2 and 3 are part of the Pulse Width Modulation bus. I understand all pins can be digital inputs but it seems none of the pins actually label as inputs are being used, why?
Also I have not reviewd the keg board code entirely yet but it appears with a few addtional setup variables, larger arrays and 2 addtional functions I could monitor 8 lines. Like I said I haven't reviewed the code and my C++ is really rusty, like 15 years ago in college rusty, but is 8 lines on one device possible.
thanks for the responses. If I get this running you might have to come check it out.
Peter
geoffculp
# Aug 13 2010 - 12:08 PM
Milwaukee, WI
Quick break from work, is it almost 5 o'clock yet?
JLPete
Not sure, but the Arduino definitely has it's quirks. See http://arduino.cc/en/Main/ArduinoBoardMega for the pin assignments.
JLPete
The Arduino Mega has 6 hardware interrupt pins which monitor\count the pulses coming from the flow sensors.
See http://arduino.cc/en/Reference/AttachInterrupt for why you don't what to use the other pins for counting the flow meter pulses.
JLPete
I'd be willing to give you a overview of kegbotmilwaukee sometime. Might be helpful for you to get going on your own kegbot.
Cheers,
Geoff
# Aug 18 2010 - 1:08 AM
JLPete
The firmware relies on external interrupt pins to perform flow sensing, and there are 6 of those available on the mega. So 6 is the practical limit.
Note that Kegbot's design allows you to connect multiple Kegboards to a host computer if you need more taps.
JLPete
# Aug 22 2010 - 5:08 PM
Milwaukee
It seems like using multiple boards is the way to go. I skip looking at modifing the firmware and go straight to setting up the Kegbot host.
Thanks for the info.
JLPete
# Sep 16 2010 - 9:09 AM
Milwaukee
[quote=JLPete]Also I have not reviewd the keg board code entirely yet but it appears with a few addtional setup variables, larger arrays and 2 addtional functions I could monitor 8 lines.
Note that Kegbot's design allows you to connect multiple Kegboards to a host computer if you need more taps.[/quote]
Mike,
I have a two boards. A duemilanove and a mega. I have configured the master.cfg to allow for two kegboard daemons. It appears I may need to modify the kegboard_config.h in the Arduino firmware so that each board connected to the host has a unique name and that name must be 8 characters. Is that correct?
Then in the database I have to update the kegtaps table with correct names something like this:
Duemilanove as name = PRIBoard
PRIBoard.flow0
PRIBoard.flow1
Mega as name = SECBoard
SECBoard.flow0
SECBoard.flow1
SECBoard.flow2
SECBoard.flow3
SECBoard.flow4
SECBoard.flow5
ozinnewy
# Oct 09 2010 - 5:10 PM
Newcastle - Australia
Hi,
I am just starting out collection the parts for my kegbot.
I have a netbook set up with the core and kegweb running.
I am looking at 2 possibilities for the arduino boards. Which is better the Uno or Mega 2560? I would eventually like to have 3 taps, so will the Mega 2560 be the better choice and will it be compatible with the firmware?
JLPete
# Oct 11 2010 - 11:10 AM
Milwaukee
ozinnewy
Hi,
Sparkfun still has just the Mega boards for $50. The Mega 2560 should be compatible with the firmware since the upgrade is really just the processor. The Arduino compiler should catch any issues if there is a problem. They also changed the USB to Serial interface. Not saying it doesn't work but these interfaces can be difficult at times. I would avoid this for a while. I have 6 taps running off the original mega board AT128. To have 3 taps you will need 1 Mega (either version) or 2 Unos. I say go with the original Mega. It will do the job and it saves a couple of bucks.
