#1 March 18, 2010 11:03:26
- skigil
0
Django Template Error
I am trying to start kegweb for the first time. I'm getting this error and can't figure out what it means:
'kegweblib' is not a valid tag library: Could not load template library from django.templatetags.kegweblib, No module named pygooglechart
Edited skigil (March 18, 2010 11:05:34)
#2 March 18, 2010 19:52:07
- geoffculp
0
- Profile E-mail
Hi, I think you might be missing the pygooglechart python package.
Check out http://pypi.python.org/pypi/pygooglechart/0.2.1 for the details. After installing you should be able to start up kegweb.
Cheers,
Geoff
Cheers,
Geoff
Edited geoffculp (March 18, 2010 19:52:07)
#3 March 19, 2010 07:16:54
- skigil
0
Yep, that worked!!
Edited skigil (March 19, 2010 07:16:54)
#4 April 17, 2010 14:52:26
- Jallen81
0
hey mike,
maybe i'm ahead of your work, but i pulled to your latest version today and now kegweb gives me errors for facebook connect. any insight?
Edited Jallen81 (April 17, 2010 14:52:26)
#5 April 23, 2010 09:38:25
- slappyjam
0
geoffculp
Cheers,
Geoff
OK so in ubuntu i did: sudo aptitude install pygooglechart. It completed okay, but when i restarted kegweb, I get this error:
I also downloaded the module tarball and copied it to /usr/lib/pymodules/python2.6/ but still the same error:
Any ideas? I'm not how to tell kegweb wehere the module is located..
any help is appreciated.
Edited slappyjam (April 23, 2010 09:38:25)
#6 April 23, 2010 14:57:46
- slappyjam
0
slappyjam
[quote=geoffculp]Hi, I think you might be missing the pygooglechart python package.
Cheers,
Geoff
any help is appreciated.[/quote]
OK I figured it out. I had to install python setuptools then do: sudo python setup.py install then it installed and worked!
Edited slappyjam (April 23, 2010 14:57:46)
