#1 Nov. 11, 2009 20:00:29
- xxrexdartxx
Keg Project and Temperature Sensor
Hello, i was hoping to find some help. I am starting a Keg project. What i have is a TS-7300 arm board with a linix OSd loaded on it. I also have an old Kegerator. The first step i want to accomplish is to have it use a temperature sensor and read the internal temp inside the kegerator. If less than my desired temp, i will have it update a monitoring website. I intend for this to be portable. If needed i have just unhook it from my kegerator and put it in another with as little hassle as possible. Can any one provide some idea's on what kind of temperature sensor i will need? Does anyone know of a good retailer who may sell these?
Edited xxrexdartxx (Nov. 11, 2009 20:00:29)
#2 Nov. 13, 2009 08:18:08
- mike
Hi there,
Temperature sensing and reporting are a subset of features supported by Kegbot's controller Kegboard, so you could certainly start from there.
If you want a digital sensor, the DS18B20 is a pretty popular choice. Analog choices include TMP36 or LM335. There are probably many others..
Edited mike (Nov. 13, 2009 08:18:08)
#3 May 22, 2010 20:43:27
- josh.dgill
Hi there,
Temperature sensing and reporting are a subset of features supported by Kegbot's controller [Kegboard](http/kegbot.org/docs/kegboard-guide/index.html), so you could certainly start from there.
If you want a digital sensor, the [DS18B20](http/www.sparkfun.com/commerce/product_info.php?products_id=245) is a pretty popular choice. Analog choices include [TMP36](http
/www.adafruit.com/index.php?main_page=product_info&cPath=35&products_id=165) or [LM335](http
/www.sparkfun.com/commerce/product_info.php?products_id=9438). There are probably many others..
For temperature sensing, you can simply use a 1N4148, or similar diode. http://www.capgo.com/Resources/Temperature/Semiconductor/Semi.html Check out part 5.. I'm going to be doing this with my kegbot once I get the time to etch my board.
Josh Gill
josh.dgill@gmail.com
BSME, University of Arizona
Edited josh.dgill (May 22, 2010 20:43:27)
