Kegbot Project
  • You are not logged in.
#1 Oct. 11, 2009 20:57:38
goliathdrakken
Profile   Send e-mail
vision 2000 fittings
I am in the process of re-plumbing my kegerator. I used to use 3/8" tubing and needed a ton of it to get the proper pressure drop. This time around I plan on switching over to 3/16" beer line. This allows me to use only about 7' of tubing. Now that I have my kegbot already to go I need to get my vision 2000 flowmeter in line some how. I am having troubles finding plastic or stainless fittings to easily interface with 3/16" tubing. What fittings are available, if any that can get me from 3/8" female npt to 3/16" barb?
Also, does anyone know how to get user pictures to work in the kegweb interface?
I plan on having a kegbot kickoff party this Friday, so I'd appreciate the help getting this plumbing problem solved by then.
Thanks, Jared
Edited goliathdrakken (Oct. 11, 2009 20:57:38)
#2 Oct. 11, 2009 21:12:17
pnielsen
Profile   Send e-mail
You need to go with 1/4" fittings. They will fit fine on vinyl tubing. Use a heat gun to heat the vinyl and it will slide right on...
For instance a 3/8" FNPT to 3/8" John Guest fitting and a John Guest 3/8" stem to 1/4" barb fitting.
This is the fancy solution previously suggested on this list. Cost is ~$8 per FNPT-JG/JG-barb combo. I don't remember the manufacturer of the JG fitting, so please do an archive search for the part number.
Alternatively, my suggestion, not previously mentioned here on the list: US Plastic has a 3/8" FNPT to 1/4" barb for $1.39:
http://www.usplastic.com/catalog/variant.asp?catalog%5Fname=USPlastic&category%5Fname415&product%5Fid416&variant%5Fidb222
This $1 part is FDA approved just like the $8 solution previously suggested on this list.
Peter
Edited pnielsen (Oct. 11, 2009 21:12:17)
#3 Oct. 11, 2009 21:35:10
Profile   Send e-mail
Hi Jared,
On Sun, Oct 11, 2009 at 9:04 PM, Jared Szechy goliathdrakken@gmail.com wrote: > I am in the process of re-plumbing my kegerator. I used to use 3/8" tubing > and needed a ton of it to get the proper pressure drop. This time around I > plan on switching over to 3/16" beer line. This allows me to use only about > 7' of tubing. Now that I have my kegbot already to go I need to get my > vision 2000 flowmeter in line some how. I am having troubles finding > plastic or stainless fittings to easily interface with 3/16" tubing. What > fittings are available, if any that can get me from 3/8" female npt to 3/16" > barb?
Looks like our resident fitting expert (Peter) has already handled this.. :-)
Profiles are a bit lacking right now. I'll have a bugfix for this (along with a bunch of other improvements) this week.
Cool. I should be on #kegbot a bit more this week. I'm working to knock several things off the TODO list and do an official versioned release of the software.
Edited mike (Oct. 11, 2009 21:35:10)
#4 Oct. 11, 2009 21:40:29
goliathdrakken
Profile   Send e-mail
Peter, thanks for the advice on the fittings. I was leaning in that direction of stretching the tube over a 1/4" fitting. Good to hear that works.
Mike, looking forward to the bugfixes and updates. I'll be on #kegnet as well, let me know if you need some testing done.
-Jared
Edited goliathdrakken (Oct. 11, 2009 21:40:29)
#5 Oct. 12, 2009 15:51:58
geoffculp
Profile   E-mail
Hey Jared,
I also bought those same exact fittings to use in my kegbot. The price is reasonable and the shipping charges weren't too expensive. They also ship quickly.
I was wondering what type of thread sealer should I be using for these fittings? Telton tape or some type of Pipe Thread Compound? None? Just wondering what other people are using.
Cheers, Geoff
Edited geoffculp (Oct. 12, 2009 15:51:58)
#6 Oct. 12, 2009 15:57:08
quentusrex
Profile   Send e-mail
Ok, can we get a parts list going? It sounds like we have the different groups of parts well understood.
Flowmeter: - SwissFlow - The other one
Fittings from flowmeter to tubing: http://www.usplastic.com/catalog/variant.asp?catalog%5Fname=USPlastic&category%5Fname415&product%5Fid416&variant%5Fidb222
Also, can we get a list with the most common tubing dimensions? To make things easier to follow for the archives.
-William King
Edited quentusrex (Oct. 12, 2009 15:57:08)
#7 Oct. 12, 2009 16:01:57
geoffculp
Profile   E-mail
In case anyone was wondering: Here's a link showing the different beer line types and sizes.
http://www.micromatic.com/draft-keg-beer/hoses-portfolio-cid-21.html
Edited geoffculp (Oct. 12, 2009 16:01:57)
#8 Jan. 2, 2010 01:21:41
josh.dgill
Profile   Send e-mail
Hey all,
My name is Josh, I'm new here. I've been lurking for a while, and finally decided to build a kegbot.
I'm looking at this flowmeter: http://cgi.ebay.com/NEW-SWISSFLOW-SF800-INFRARED-IN-LINE-FLOW-METER_W0QQitemZ370193262782QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item56313ce8be as it seems to be popular here. Looking at the thread specs on the SF800, the threads are BSP, not FNPT. I am having trouble finding barb fittings in metric. Am I just going to have to get a FNPT -> BSP coupler?
Josh
Josh Gill
josh.dgill@gmail.com
BSME, University of Arizona
Edited josh.dgill (Jan. 2, 2010 01:21:41)
#9 Jan. 11, 2010 23:00:42
kgrewohl
Profile   Send e-mail
I've been using the Parker fittings seen here:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=2ZTF7&op=search&Ntt=2ZTF7&N=0&sst=All
My success has been great with them so far. A little bit of leaking, but probably my plumbing skills. Or possibly due to the difference in threading. The are really nice connectors though.
Edited kgrewohl (Jan. 11, 2010 23:02:45)
#10 Jan. 19, 2010 16:46:56
josh.dgill
Profile   Send e-mail
To follow up on my previous post-
I contacted SwissFlow and told them my application, they shipped me all of the fittings needed. Time to start programming the uC!
I'll start a build thread when I get some results.
Josh
Josh Gill
Edited josh.dgill (Jan. 19, 2010 16:46:56)
Board footer
Moderator control
Powered by DjangoBB
